Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...A lot of the information I've found at this site would've taken me forever if I'd have attempted to research it on my own. Thanks again."
Geography
Effective stress/Overburden calculation method
Darrensw (Geotechnical)
2 May 06 12:11
I work in a UK independent soils laboratory and often receive samples from clients that want permeability, UU triaxial or shearbox tests, but the client fails to supply the effective stress details. When asked the pressures to be applied to the samples, they often don't even know they are required to specify them, let alone what they should be.
I wonder if anyone knows where I can find a published method of calculating overburden pressure and effective stress from the sample depth and can point me to a document I can use.
Thanks.
Darren
BigH (Geotechnical)
3 May 06 1:19
mmmmhhh - I thought this was geoengineering 101?!!  Pick up any soils book and they will tell you how to calculate overburden pressure.  Simplistically, Total pressure = unit weight x depth to consideration (adjust unit weight and thicknesses to stratigraphy).  Know where the water table is and subtract off the pressure due to the weight of water above your point = effective pressure.
Close Box
Join Eng-Tips® Today!
Join Us             Close
