SW2006 instability on W2K machines?
My company is still using SolidWorks 2005 sp. 3.1 We are willing to upgrade to SW2006 sp 3.4 We run some tests on both XP sp 1.0 and W2K sp 4.0 machines.
It seems to be more stable than SW2005 on the XP machines, but on the W2K machines it is much more unstable. This is a showstopper at the moment to go over.
Could it be that we are still using MS Office 97'?
SW2006 still support W2K, but MS Office 97 is not supported anymore.
RE: SW2006 instability on W2K machines?
Then you need to upgrade your MS Office. You also need to check your video card drivers to make sure they are the correct ones for W2K. If they are not then that cold be the problem. ALso remember you need to do a new install of SW06 and not an upgrade of SW05.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Another thing to note.  SolidWorks 2007 will not be supported on Windows 2000.
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com (updated 5/01/06)
SW 2006 SP 4.0
Also note that SW recommends XP Pro with SP2.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Thanks for the info. I was aware of the last two posts. Unfortunately, our IT department is currently working on a budget, and they seem not to care.
We are on XP pro sp1.0 And they are unwilling to upgrade for some very strange reason noboby seems to understand.
I will try the videocard driver first. If that does not work Office has to be upgraded.
I have Windows 2000 Professional on my home computer and SWx 2006 works like a charm.  I have updated my video drivers and use the newer version of MS office.
What characteristics is the W2K machine doing that makes it unstable?
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
