PV-CodeCalc Software
I am looking for a software to help set up a inspection program that will cover Sec. I, IV, VII vessels primarily.
I have looked at several of the ones out there but so far the most impressive is the OSS software Ultra Pipe.
Does anyone have any other suggestions?
RE: PV-CodeCalc Software
Our inspection department purchased the UltraPipe software a few years back and are satisfied with it.
You could consider PVElite from COADE.  It has a 3D interface where you can see the vessel as you 'build' it on the screen, and it is childishly simple to use. It also has a component module that allows you to desing heat exchangers to TEMA and ASME, as well a lot of other good stuff.  It is available from COADE (www.coade.com)
HI Raydel (Mechanical)
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
PVElite from COADE dose not do ASME SECTION I RULES FOR CONSTRUCTION OF POWER BOILERS; ASME SECTION IV RULES FOR CONSTRUCTION OF HEARING BOILERS.
Leonard@thill.biz
www.thill.biz
hi all
i think coade software(pv ellite)is the end of line.
best regard.
Hi MicroEng (Mechanical)
What Engineering Tool's for:
ASME SECTION V NONDESTRUCTIVE EXAMINATION
ASME SECTION VIII  RULES FOR CONSTRUCTION OF PRESSURE VESSELS DIV. 1 and DIV. 2
ASME SECTION IX QUALIFICATION STANDARD FOR WELDIG AND BRAZING PROCEDURES, WELDERS, BRAZERS, AND WELDING AND BRAXZING OPERATORS
meet your requirement for Reliability Engineer and the new requirement as Owner User in the National Board Inspection Code ANSI/NB 23 December 31, 2002?
