Some of my tool bars don't work ?
Ok say I bring in a parasolid model an need to split it up
and do some other things.I find alot of my toolbars don't work and they are not even highlighted in need of help.
RE: Some of my tool bars don't work ?
Is this something that changed? What version are you on? What equipment do you have?
I suspect you need to do the import and save the part before you can do anything to it. Only the toolbars appropriate for part changes will be active.
Hardie "Crashj" Johnson
SW 2005 SP 4.0 (reluctant to change)
Matrox Millenium G550
AMD Athalon 1.8 GHz 512 Meg RAM
2.)SW 2004
3.)Pen.3.2Ghz,2gig of ram
4.)The customer has UG NX
5.)I have imported an saved an the split toolbar still is not working, If i use SW to model up something all toolbars work.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
2.)In the past it was surfaces
