high voltage power supply
Hi all,
I going to design a power supply with 6KV / 700uA (<30mv ripple) output and 10 Volts DC input?
its based on push-pull transistor driver for ferrite transformer input and a N stage (diode-capcacitor pump) voltage mltiplier?
How can I calculate capacitance of capacitors & number of stages?
Rgards,
John
Rgards,
John
RE: high voltage power supply
I assume if you Google 'voltage multiplier' and variations you should be able to find some good info. Adding .pdf to the search terms often helps in floating better info up to the top.
I don't suffer from insanity. I enjoy it...
photomultiplier
