composiet calc
composiet calc
composiet calc
can you do a calc in catia  for composiet´s
since there is a mat. option for fiber mat  and anisotropic  mat
but when you try to make a tube it cannot do that in composiet
so even to do a calc of 2 tube´s  is that possible
or do i something wrong?
RE: composiet calc
Do you mean do a stress analysis of the bdy using composite materials definitions from CATIA?
I think it works with simdesigner (MSC) but don't know if the native solver supports it.
Do you have any tutorials/guides to the composite module (except for the CATIA help)?
Jake
RE: composiet calc
yes that what i mean in catia at it seems does not support
tubing at least you can not fold a layer over a solid
or make in any other way a tube
i liooked in the tutorials /guides   and also i did a quik look with MSC  simdesigner  nothing only mention of flat plate´s
i think due to the hex mesh   and only supports isotropic
with is strange since you can define the fibers and directions
only no clac  with i find kind of stupid
so must be my short coming
RE: composiet calc
as far as I know, solid elements can't be defined as laminate. For laminte use shell elements, and then the properties are orthotropic.
If you are modeling a single material layer, then it can be orthotropic, but it won't have layers.
RE: composiet calc
i understand that but if you make a model in a core
like foam as basis and want to wrap around layers oc carbon in a weave like pultrusion
or simply a round layup  of you you can define it as a shell then othotropic but catia would not let me
it must be me that does not understand it
must be in the mesh model
hence it must be 3d
so what i do
1 simply draw a profile in sketcher  then exit
2 extrude   make a shell out of it
3 goto composite module
4 drap a layer around it
and this cannot be done why not?
and why can you not calc a tube in composite
