I am looking for a way of checking
I am looking for a way of checking for good connections in a system where an insulated wire is put into a water bath for hipot testing.
At present, I only know that I have voltage going into the wire if the wire is bad, creating a ground loop through the water. How can I measure if I have a voltage potential in the wire if there is no failure?
The opposite end from the connector is insulated and submerged.
RE: I am looking for a way of checking
a low frequency ( e.g. 1 KHz ) on the HV?
<nbucska@pcperipherals.com>
