Turning Radius WB-40
Looking for a way to check the turning radius and sweep path of a semi-tractor in reverse.  The templates I have, I've been told, are only for forward movements.
Thanks.
RE: Turning Radius WB-40
I highly recommend AutoTURN by Transoft.
 Imagineer
Auto Turn.  It works with AutoCAD or Microstation
If you can drive it forward, you can drive it back.  That said AutoTurn is pretty slick.
Another good program is AutoTrack. (www.savoy.co.uk) Very easy to use, and a wide range of design vehicles.  Cheaper (by about half) than AutoTurn.
