BOM QUANTIY EXTRACTION
Does anyone have a macro to extract the quatity of parts in an assembly or from a bom and have it update the file properties?
Thanks.
Thanks.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: BOM QUANTIY EXTRACTION
If I understand you correctly. You could use Custom Properties for this issue? You can create new ones if required. Hope this helps.
Cheers,
Ralph Wright, CSWP
SolidWorks 2005, SP5.0
P4, 2.53Ghz
1.5 Gb RAM
ATI Fire GL8800 Card
Windows 2000 Pro
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Cadmiester, what is your familiarity with VBA? Would a good starting point and a few pointers get you to where you can figure it out, or are you needing a plug-and-play solution?
It sounds to me like you need this functionality for assemblies with more than a few parts. However, if I'm wrong and you only care about a few critical parts then FAQ559-1232 may be able to help you some.
Have a great day!
That will get you the quantities for a starter.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
