CosmosXpress on a SW 2000 assembly?
Hello I am new to SolidWorks. Is it possible to use CosmosXpress to perform a FE analysis on an assembly in SolidWorks 2000. If so, could anyone provide some tips to get started.
Thanks in advance.
Thanks in advance.
RE: CosmosXpress on a SW 2000 assembly?
CosmosXpress can not be used on an assembly. It only does parts, but you could make the assembly a part then it would work. The results would be a rough idea because the assembly is now part (one solid piece). Hope this helps.
Cheers,
Ralph Wright, CSWP
SolidWorks 2005, SP5.0
P4, 2.53Ghz
1.5 Gb RAM
ATI Fire GL8800 Card
Windows 2000 Pro
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Cheers
Greg Locock
