Hi, I'm trying to put the shop floo
Hi, I'm trying to put the shop floor assembly section into a standard operation and conduct a work measurement to get a standard time. But the problem is there are so many processes such as nut fasterning, belt, chain, pulley, etc. to be assembled and isn't need to identified each task to one standard procedure...seem this would take times...anybody could help...thanks!
RE: Hi, I'm trying to put the shop floo
Is the goal to get a standard time so you can see where you are; then improve it?
Read a book called "Lean Thinking" by james Womack and Daniel T. Jones. It will give you an introduction to Lean Manufacturing. It will also give you the steps.
I would first determine the value stream of your process. Really look at all the movement and que's that are there in between each step of your process...that is waste (very big deal when looking for improved production.)
Value stream analysis is by far the best tool that is often overlooked when doing any process improvement. Look at "Learning to See" by Mike Rother and John Shook. This book takes you step by step through the analysis (something that Womack and Jones didn't go into detail over.)
Divide the process into segments, if they are not clearly defined, use que locations as cut-off points until they too are gone. When you have these divisions, do a time study and compare process time to takt time. It will really illustrate the areas that need improvement.
If work procedure documentation is your goal (like ISO or QS), then this process will also help you identify the areas in which to document.
If you have any specific questions....post them. We get a lot of good feedback around here.
Carl
Swaco
