AB PLC SLC 500
AB PLC SLC 500
If I have a Printer connected to the 9 pin connector can I still use a PC to communicate with the Processor?
RE: AB PLC SLC 500
I don't suffer from insanity. I enjoy it...
RE: AB PLC SLC 500
If its the SLC 5/03/04 there is two ways to communicate to the processor from a pc. The round 9 pin connector DH45 comms or the RS232 port. Depending on which port you have your printer in use the other port to communicate. You will just have to set your drivers up in RSlinx. Hope that helps.
Blue
RE: AB PLC SLC 500
Incidentally, when did the SLC5/03 develop a round connector? Unless things have really changed, the DH-485 is on an RJ-45 connector, and the RS-232 is on a 9-pin DIN connector.
RE: AB PLC SLC 500
RE: AB PLC SLC 500
I've also had a play with a NET-AIC as a stop-gap when the 1747-PIC was misbehaving. It's ok if you have 24V DC available and accessible to tap into, but doesn't look very professional.
