Static Load Testing of Wood Structures
Is anyone familiar with a method for static load testing on a wood structure? I know this is usually only a typical method for concrete structures since wood and steel members can be field measured and analyzed, but the structure I am considering has some deterioration and the owner has expressed interest in a full-scale investigation.
I have checked ASTM, but have had limited luck. Any leads would be appreciated.
RE: Static Load Testing of Wood Structures
"Testing of a Full-Scale House Under Simulated Snowloads & Windloads"
ht
"Nondestructive Assessment of Single-Span Timber Bridges Using a Vibration Based Method"
htt
and a follow-up
ht
www.SlideRuleEra.net
That's an AMAZING paper. A printout goes in my library next to ASCE 7.
