FRP versus HDPE for Underground Sewege Odor Control Exhaust
I am working on a odor control (exhaust) project for a waste water treatment plant. The underground duct needs to be 12" dia, and the air stream contains H2S. Shall I use FRP or HDPE for underground section? Any advantage to use HDPE instead of FRP?
Thank you in advance.
RE: FRP versus HDPE for Underground Sewege Odor Control Exhaust
HDPE is a more consistent product required to comply with USA, ISO or other national codes, whereas FRP can be sourced from a variety of manufacturers to many standards. IF the procurement guys buy on price you could end up with a pack of pooh tickets.
Will PVC 80 be a better option versus HDPE for this burried application?
