Surface Symmetry
Surface Symmetry
Surface Symmetry
I searched previous threads and go close but not exacatly.  In Assembly Design is there a way to Symmetry-Mirror any data other than solids/PartBody.  I am looking to mirror RH data to the LH in the product.
When I use Symmetery and the CatPart only has surface in GeoSets, there is now result.
Ross.
Ross Parpart
Product Design Engineer
UGS NX3/CATIA V5R15
www.decoma.com
RE: Surface Symmetry
Ross - In Generative Shape Design (GSD) go to Tools-->External View.  Select the surface to symmetry.  If it is more that 1 surface create a join with non-connectivity turned on. You can only symmetry the external view or the partbody, not both. I wish you luck with the symmetry.
Derek
Derek,
I know how to do it in a CatPart but I want to do it in my CatProduct.  So far I can only get solid data not any surface to work.
Ross.
Ross, follow preview response about external view.  In assembly design Insert --> Symmetry, pick plane, pick CATPart.  your external view surfaces are mirrored.  You can not symmetry both solid and surface, it is 1 or the other from what I understand.
Derek
