Extrude Complex Sketch
I am new with SolidWorks (2003 SP3.0). I've done the basics in the tutorial, and have put in about 10 hours so far.
My question is how to extrude from a complicated sketch. The error I encounter with any sketch more complicated than a single square or circle is:
Code:
 Extrude27: The sketch cannot be used for a feature because an endpoint is wrongly shared by multiple entities.
This is for sketch "Serpentine1".
I think this an easy question, but I can't figure it out after many hours of trying.
Any help would be much appreciated.
my file can be found here:
http://www.mcadforums.com/forums/viewtopic.php?p=36258
Thank you!
RE: Extrude Complex Sketch
Get rid of the lines that fall accross the tangents of the arcs. I deleted them in your posted file and it will extrude a boss or a cut. Use tools/sketch tools/check sketch for feature to find the error.
You could also just convert the "tangents" to construction lines.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
