ground wire - resistance grounded
Hello all,
Typically we run a ground conductor on a feeder that is generally one size down from the phase cable size.
Since I work in mining, typically all the systems are resistance grounded and by code generally the MPC's have a main ground of #8awg....
Why do I run anything larger than this on the secondary feeders???
TULUM
RE: ground wire - resistance grounded
Sorry to explain further the systems generally have 5, 10, or 15A NGR's and the feeders are close coupled?
TULUM
I think the NEC ground wire sizes are based only on the feeder rating.  System grounding is not a factor.  I suppose the concern is that a resistance-grounded system could be easily changed to solidly-grounded in the future.
