offset feature?
offset feature?
offset feature?
I have a disk shapped part with concetric cut rings with incresing diameters (see pic).
http://img175.imageshack.us/img175/3941/part6hv.jpg
My question is how to model the rings (easily).  I did it by offsetting my original sketch.  I think this is  around about way to do it.
Could you cut one ring and offset that feature? To my knowlegde there is no such command.
Thanks.
Grant
Applications Engineer
SW2006 SP 4.0
IBM InteliStation Pro M
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 3000
RE: offset feature?
Something like this, I would have made a sketch of all the grooves and revolve-cut the features.  That way if the spacing or sizes had to change, I would only have to edit one sketch.
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: offset feature?
If you have to do this type of feature often, you could create a Library Feature which could be dragged, dropped & resized to suit ... much like a "face-static" O-ring groove.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: offset feature?
Or draw the cross section and revolve boss
