How do I determine a ASTM A478 Casting pressure class?
I have a casting which I would like to have rated to a 600 pressure class.  The material is ASTM A487 type CA6NM.  I am running a FEA and need to input temperature and pressures to meet 600 pressure class requirements.  What temperatures and pressures do I use?
My confusion is that I can't seem to find ASTM A487 in any of the tables in ASME B16.5.  I know actual pressure change for each material.  Should I just pick the highest values (1500 psig @ -20 to 100F, 1330 psig @ 500F)?
FYI - I want to run the FEA at the temperatures above as this is the operating temperature range of the casting.
Ben
RE: How do I determine a ASTM A478 Casting pressure class?
If you are interested in pressure-temperature rating methods, I would highly recommend you read Annex B of ASME 16.5-2003.
Thanks for the advice - I've got my working pressure now.
