How to create a part from two parts
Hello I have a question . How can I create from an assembly of 2 parts a single part ?
Thank you !
Florin
Thank you !
Florin
RE: How to create a part from two parts
Create a new Product
File -- Insert from new and pick Part A. This is going to make a new independent copy of the original. Change the name to Part B.
Drag and drop this part into the assembly.
Insert Existing component - pick Part A
Delete the information you don't want in each part
The result should be an assembly with Part A and Part B.
Derek
If you wish to keep the link to the original assembly add a new CATPart to the assembly and while active in that part select all of the CATBodies from all of the other CATParts and do a paste special.
Jim
Derek
