submarine cable
submarine cable
dear readers:
I would like to ask how much is the cost of a submarine cable per kilometer which will be used mainly for electricity.
Is it also possible that a submarine cable can be used for both electricity and communications and also the cost or expense in the maintenace of the submarine cable. please help me. Thank you.
RE: submarine cable
What sort of communications ? What distance, what bandwidth is required ? are submerged repeaters required ? Too many variables.
RE: submarine cable
All the purchase information (Technical information) are given in API 17 E.
It is very common to have Communication cable along side the Power cable.
Check with Presmian
Also there is company in South Ameriac (Brazil) Oceaneering.
You may also check up with Technip Co flex (i think in scotland)
RE: submarine cable
RE: submarine cable
respectfully
RE: submarine cable
Yes, submarine cables can be used for both application - electricity and communication medium (usually fiber optics.
What is the capacity of your system? I need to know, if you mind, the MVA, KV, Monitoring scheme, etc.
RE: submarine cable
Cheers
Zoomi
RE: submarine cable
