Water pipe and fittings online catalog
Somebody knows good online catalog for large water pipe & fittings, i. e. pe pipe & fittings, pe to asbest cement transitions and similar?
sunshine
RE: Water pipe and fittings online catalog
Tyler Pipe has a very handy online catalog of DI fittings.
You might check the coupling company websites as well- Dresser, Smith-Blair, Romac, for example.
What exactly are you needing?  PE-AC transition is not exactly a common item.
you are right, I'm trying to find some more complex coverage for multi-material water supply systems.
I didn't perpare such specification for couple of years. What happened in the meantime? Most of what I find in the offer is no-pressure soil systems!
