ACDC EL-300 Electronic Load info
I purchased a used ACDC EL-300 Electronic Load to do some testing on a converter.   I was a little surprised it didn't have a switch to operate in either constant current or voltage.  It works, but from my limited testing acts more like a resistor.  There is a 10 pin jumper plug in the back that may enable a constant voltage or current function.  Anyone have any information on this unit or plug wiring?   I've searched the net and haven't found anything.
RE: ACDC EL-300 Electronic Load info
www.ManualsPlus.com
Link to the EL300 manual:
http://tinyurl.com/fcnt3
Details:
Manufacturer:  ACDC
Model:  EL300
Description:  OP-SV
Part Number:  MP-31388
Condition:  Reprint
Price:  $35.00
The problem with manuals is that they are more expensive than the units themselves.  I would have thought that someone here was using one of these.  An amplified zener that can sink 60+ amps sounds pretty dangerous for most power supply testing, but that is what I need.  I have a spare unit that is less than prime that I will cut some traces on and modify for this function.  Also need to supply internal 100ma power to hold up the voltage when not connected to a source.  Thanks for your efforts.
