Air flow in a pipe
Air flow in a pipe
I am looking for an equation to determine air flow (standard) in a frictionless short pipe given diameter and the pressure differential across it. For example a 2.5" diameter pipe of 1 ft length has 20" H20 pressure across it. How much air (cfm) is it flowing? Thanks.
RE: Air flow in a pipe
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
and this is constant in every section (if you are in a stable condition).
rho= density;
u=speed;
S=Area of the section that is constant in this case.
If the pipe is frictionless and the flow is adiabatic the total rho is constant (1.225 kg/m^3) so you can calculate the rho in this way:
rho=total rho*(1+(gamma-1)*M^2/2)^(-1/(gamma-1));
where
gamma=cp/cv=1.4;
M=number of mach;
