Cut Lists properties and Smart Fasteners Question
Hi -
I found this website through a search engine, so its my first time posting in here. I've been using SW since '97, in product design. I'm starting a car restoration business so I've JUST started using the weldment/cutlist function of SW.
I'm working on a design that is built out of structural steel (tube and plate) and I've built it using the weldment feature in SW. I have two questions, both related to the same project.
First Question.
The design has several plate gussets (created using the gusset feature on the weldment toolbar) that measures 10"x10"x0.25 thick. When I create the cutlist table in my drawing, I get a cut dimension of 14.162 which is the cut accros the diagonal. I need the length x width dimension. I'm assuming that I need to do a custom property in the cutlist.
How would I use the custom property screen to link to the D1 and D2 dimesions on the weldment gusset feature? (I hope that question makes sense)
Second Question:
I'm using the smart fastener feature in my assembly (made up of several weldments). When putting a bolt through a hole, (holes created with the hole wizard) I'm not getting the option of a "BOTTOM STACK". As a result, I can't put the nut/washer on the end of the bolt. Is there something I'm doing wrong that I'm not getting the bottom stack option?
Thanks for all the help!
Joe
First Question.
Second Question:
Joe
RE: Cut Lists properties and Smart Fasteners Question
2) I haven't used SmartPasteners so I don't know.
Ken
Daniel
