Choosen material not showing on all of model
Hi all,
Just ran into something odd, I modeled a drive shaft with multiple diameters some threads and keyways. When I applied the material alloy steel the color of some of the diameters changed but not others. Has anyone run into this? I'm using simplified material so it's not textures just color change. Any ideas? Thanks,
Dennis
SolidWorks 2006 SP4.0
Windows XP Pro, Pentium4 3.00GHz
1.5 GB RAM, Matrox P650
Logitech Marble Mouse, CADMAN
RE: Choosen material not showing on all of model
Maybe some surfaces have color override? Or maybe your video card?
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
The Appearance Callouts in SW06 should make it easier to assign/check feature colours.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Faces or features with colors assigned will not update when a material assignment changes the underlying body color. Makes me crazy.
Hardie "Crashj" Johnson
SW 2005 SP 4.0 (reluctant to change)
Matrox Millenium G550
AMD Athalon 1.8 GHz 512 Meg RAM
Actually it makes sense (to me anyway) that a change to a parts material does NOT change the colour of individually assigned faces. Assuming you needed a face to be a different colour from the rest of the part, (e.g. to denote a painted surface) why would that change because the material changed?
cheers
What would be really nice is, when changing the material, you were given the option of changing all faces/features to match the material colour, or leaving them as assigned.
cheers
I agree that there is good reason to not change. It surprises me when I do not realize I had made a detail color change.
There is a macro available at
http://www.trimech.com/solutions/techsprt-free-utilities.htm
that removes the color assignments from all faces and features in a part.  If this is something you come up against often you can get that macro and run it prior to assigning your material.  I combined that macro with another on that site (Random Color) which I use all the time when I import IGES files for purchased parts in my machine designs.
Thanks everyone, I'll go back and investigate per all your suggestions. I love this forum....
Dennis
Update:
I checked the display pane and no colors were assigned to any of the individual features. I downloaded and ran the macro handleman suggested. I applied the material and it worked perfectly. Now I'm not sure why but everything looks like it should. Again I love this forum.
Dennis
