HCl to sulfuric acid tank
I have an FRP tank lined with PFA which was once used to hold 35% HCl (at room temperature and atmospheric pressure).
I am considering converting that tank over to a concentrated sulfuric acid tank (same conditions).
So I want to know if I can do this. The chemical resistance for sulfuric and HCl with PFA is alright, but the chloride ions can permeate (essentially diffuse) through the PFA liner and I am wondering if that will cause a problem structurally to the tank or even if chloride ions can diffuse back into the tank and contaminate the sulfuric acid.
If anyone has any info or a link to a paper about this, I'd appreciate it.
RE: HCl to sulfuric acid tank
NB
