Help with automation (macro)??
Can anyone help me? im using solidworks and PDM. i have several hundred drawings all of which i need to put a logo/stamp on. ive looked at using ole objects or inserting the details into the boader but i want to speed up the process and also not make it to difficult to change. ideally i want to run an automated tool/macro from explorer where i can pick all my drawings!
has anyone done this before?
RE: Help with automation (macro)??
Flores
SW06 SP4.0
Then save your work.
Of course, "SW-CreatedDate" is available. This can be short form or long, with or without time. Does that do it for you?
"works for me"
Hardie "Crashj" Johnson
SW 2005 SP 4.0 (reluctant to change)
Matrox Millenium G550
AMD Athalon 1.8 GHz 512 Meg RAM
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
top bloke for your sugestions so far
cheers
[suggestion]
Given that you're a "virgin to VB" you would probably spend almost as much time or more learning the VBA to automate the job as you would actually doing the job manually. It sounds to me like your quickest option would be the one suggested by smcadman and CBL. $50 for PropaGator is probably worth the time saved.
[/suggestion]
[editorial]
You mentioned that you're contracting with this company. This is going to sound very management-like, but unless you're a pretty long-term contractor the best thing for the company would be to go the PropaGator route. When you've headed off to your next job they'll still have the software as an asset they can re-use. If you were a regular employee they could probably justify the time spent learning VBA as education, and then you would be additional asset for further automation tasks. Otherwise they're paying you to add an asset to your own skill set that you will take with you when you leave.
[/editorial]
