High side to low side and back again
Just wondering if it is possible to set up a high side and a low side screw compressor so that either one could be the other. Umm, best clarify a bit.
Arrange piping and valves so that if your booster goes down you can switch the high side compressor over to low side. Of course you would also have to have a switchable control panel so the high side would "know" it is now a booster. Use motorized valves for speed and convenience.
Has anyone ever done something like this? Is it possible? If not, why?
RE: High side to low side and back again
