pump for molten zink
I need a positive displacemant pump to pump molten zink at five gpm and 100 psi.  Does anyone know where I can get one?
RE: pump for molten zink
With regard to your need for a "molten Zinc pump"
I suggest that you contact the technical rep's at Viking Pump...
www.vikingpump.com
They have experience with this type of "hot metal" pump and have supplied pumps for both lead and zinc.
The pump is an internal gear, positive displacement pump without a seal ( Your pump efficiencies are going to be low)
The real trick..... in the plant layout, is to  keep the motor cool
Good Luck
MJC
