Rubber hardness-mixing?
We have problem with rubber hardness it is sometimes higher and sometimes lower with same raw materials, so could somebody tell me how can we encrease hardness during mixing step in our production. Does the odrder of adding raw matterials has some infulance of the hardness or temperature or something else. Of course I know that hardness is function of filler properties and quantity.
Thank you.
Thank you.
RE: Rubber hardness-mixing?
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
