AGTEK software
AGTEK software
The company I work for is deciding to purchase AGTEK grading takeoff and modeling software. What is everyones positive and negative feedback on this software? Is the most popular available, or does anyone recommend other vendors? We are a grading contractor and will use it use for bid takeoffs, GPS modeling for earthwork equipment, and timely billing quantities. How much planning and management time do you spend with this software?
RE: AGTEK software
In terms of money, to do an electronic dirt take off is the way to go you have a 180000cy job and you will spend a month working, with this programs you can spend a day and you are done and more acurate than anything
RE: AGTEK software
Check out this post
RE: AGTEK software
RE: AGTEK software
