Off the Shelf LEV Hoods for 55 Gal Drum Bungs
Hi, I'm new to this forum and I need some help. I am looking for "Off the shelf" LEV capture hoods that can be attached to the end of 4" to 6" diameter flexible hoses to capture solvent vapors for 55 Gal drums. We use vacuum to extract the solvent from the drums and need the capture hood designed and labeled to provide the correct static pressure. I have not been able to find just the hood itself, (I.E. Nederman). Any thoughts will be helpful.
MOE
MOE
