alter temperature values in the RTH file?
I was wondering if I could change the temperture values in the RTH files of the transient thermal analysis such that any node with temperature above a particular 'X' value can be modified to become the 'X' value
is there someway this could be done right after a particular step is calculated or after the entire analysis?
thanx
Robin
RE: alter temperature values in the RTH file?
I would try the DNSOL comand.
Alex
