Stock motor fuel curves, and sensor function?
Is there a way I could get information from ford on how a vehicle reacts in different situations such as variable RPM, throttle position, and car speed. Information such as shift points (or equations for them), air/fuel mixtures (depending on TP, speed, and RPM), and etc. Anyone could hook up a computer and get information, but I'm looking more toward what ford wants for a stock vehicle, and how any aftermarket products I develop should effect the vehicle to give me an idea of where to start. Any help is greatly appreciated!
RE: Stock motor fuel curves, and sensor function?
It's not reasonable to hope they'd give you this information.
You're free of course, to attempt to reverse-engineer your way to this knowledge.
Good luck!
You're nuts, that'd take way to much of my time. Do you know who I could contact to get this Proprietary information? Thanks again!
I tried to build an analog system for motorcycles and after the o2, throttle position and crankshaft position I already had two more sensors then I knew what to do with. The problems of who has priority, and what amount of influence does each one have drove me to use an existing microporcessor unit .... Good luck to you and about 10 talented engineers.
Cheers
You'll need TPS, vehicle speed and preferably MAP.
Then just drive at constant MAP or TPS noting the change points.
While this won't give you the details, it'll give you the rough shape of the shift schedule.
Cheers
Greg Locock
http://www.sctflash.com/product_racer.php
regards
Pete
LOL!
So your time is valuable, but no one else' is?
When you learn enough to realize the scope of what you're asking for - for free! - you'll realize what a silly request it is.
Your best bet is aftermarket tuners that have reverse engineered there way to that information at great expense.. again, they will likely not hand it over gratis..
Option three.. keep searching the net and you will find clues to how it all works and peice together an understanding of the relationships of all the inputs and outputs over time.
As for what ford wants from aftermarket add-ons.. generally i think you'll find they want you to leave their stuff alone.
