Toolbox not installing from admin image
I recently installed SW 2006 on 2 machines from an admin image on the server using the command line. Both machines run Windows XP. The trouble is that the toolbox did not install even though I had specified it. The command I used was as follows:
msiexec /i english_i386_solidworks.msi INSTALLDIR="C:\Program Files\Solidworks" TOOLBOXFOLDER="O:\SOLIDWORKS" OFFICEOPTION=1 SOLIDWORKSSERIALNUMBER="0000 0040 XXXX XXXX" REGCODE=391CC3HB UPGRADESWINSTALL=1 /qb+ /l "\\fdi-s01\support\SW ADMIN IMAGE\LOGS\fdi-c03_sw2006sp4.1.log ADDLOCAL=English,SolidWorks,AddIns,SupportedLanguages,SolidWorksTaskScheduler,FeatureWorks,SolidWorksToolbox,SolidWorksUtilities,SolidWorksDesignChecker
Any suggestions as to why?
Thank you,
Thank you,
Craig Sink
Mechanical Engineer
Force Design, Inc.
RE: Toolbox not installing from admin image
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
I didn't actually install SW on the server, I just created an admin image. The toolbox folder is on the same server as the admin image, accessible by all computers on the network.
I'm not sure if that makes sense or answers your question...
Craig Sink
Mechanical Engineer
Force Design, Inc.
Chris
AutoCAD 06
FAQ559-1100
FAQ559-716
To clariy, what I'm trying to accomplish is to have an admin image on the server. Then install all computers from that image. The differences would be specified via the properties documented in the SW installation guide which is primarily the serial numbers and registration codes. I'm gathering that this is only possible if I have a working installation of SW on the server with an admin image created from that?
Hope this clarifies it. I've gotten a lot of conflicting information, so I'm trying to sort through it.
Craig Sink
Mechanical Engineer
Force Design, Inc.
Chris
AutoCAD 06
FAQ559-1100
FAQ559-716
Now to take it a bit further, can I do the installs silently, as in via the command line, or will that not work the same?
Craig Sink
Mechanical Engineer
Force Design, Inc.
http://w
htt
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
You need to install SW on the server with all links setup.
thread559-96748
Chris
AutoCAD 06
FAQ559-1100
FAQ559-716
I've got those references and have read them. I'm following the examples, but its not working as I stated in the first post. I can't see anything wrong with my command and I had installed SW on other systems prior to that with no problems. The only difference being that this time I installed from the command line with a silent install rather than by clicking on the swsetup.exe file.
The other thing not clear to me is how to create an admin image from the working SW installation on the server rather than from the cd itself.
Thank you,
Craig Sink
Mechanical Engineer
Force Design, Inc.
