molten tin and Hastelloy
I hve been handed the job of findinga replacement valve for our tin anode caster. I was told it is hastelloy lined and is replaced every 4 onths due to leaking. It shows signs of pitting and the tin in bonding with the Hastelloy. Can anyone tell me a good coating to use instead of Hastelloy?
RE: molten tin and Hastelloy
... as a start. This from a Google search using the terms "tin die casting mold steel".
