Maximum Lengths for Sawn Lumber
Is there any good sources out there for the maximum available lengths for sawn lumber? Such as, if I use 2x12 rafters, how long can I get them before I have to go special order or it becomes not available?
RE: Maximum Lengths for Sawn Lumber
http://w
The American Lumber Standards Committee does not address length, other than specifying 2' increments. Here is the "American Softwood Lumber Standard"
h
www.SlideRuleEra.net
Another thing to consider is how straight will a 22' length piece of lumber be?
Consider TJI's?
DaveAtkins
Regarding the long rafters, consider scissor trusses maybe or other type products. Maybe glulam ($$$).
Dik
Of course the school was built in 1920s.
By the way, anyone has published date on Miami-Dade pine?
Lutfi
As a designer, I would be concern about the deflection of a memeber 22 ft long but looking at SPF span charts.
http://www.southernpine.com/pdf/table02.pdf
With a 40 LL 10 DL Loading L/360
A 2X12 #2 @ 12" o/c is good for 21'-9" CLEAR!!! My have to require a #1 but not a uncommon requirement
