Calculating # of tie downs needed
Hi all,
I'm fastening a pallet with about 8000 lbs of equipment on it to the inside of a standard ISO shipping container. I plan on using the t slot flooring that is in place in the container to fasten to using some custom t bolts I am making up.
My question is how do I calculate the # of tie downs/fasteners I will need for this? The pallet is approx. 12ft x 4ft footprint with a center of gravity 31in off the floor. I was going to use a 1/2 t bolt to secure the pallet.
This is a permanent type of installation, hence the reason i am using the t bolts instead of something quick and easy to lock down.
Thanks!
Thanks!
RE: Calculating # of tie downs needed
becma27, MintJulep has given the 'tongue in cheek' answer to your question. I will add that once you have your required load cases, you may want to start with a free body diagram and then engineer a solution.
Alternately, you could obtain a consultant for a relatively small fee.
At a previous job, one of the engineers worked on a similar problem to yours. He spent about a month working out a solution and isolating the equipment to protect it. Then he had to find a climate controlled container.
Good luck and don't forget the drop test....
ZCP
www.phoenix-engineer.com
If you are shipping container on ships you can download the ABS guid at WWW.eagle.org. Peck and Hale has standard connections that fit in the track.
