ProE to Solidworks
ProE to Solidworks
ProE to Solidworks
I have a customer that uses ProE, I'm not sure of his version. I'm using SW 2006 SP2.1
They sent me ParaSolid Files but Solidworks reports invalid faces and edges. I've tried running diagnostics and repairing all, but it does not work. should I ask them to re-send using Step or Iges? or is there a better option
thanks,
tom
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
RE: ProE to Solidworks
I usually use STEP.  It seems to come in the cleanest from Pro/E.
-b
Yes, have them send both STEP and IGES. See which works best for you. From my experience, I ask for either depending on the company.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Thanks, I'll ask for both
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
I go back and forth from Pro/e 2001 and SWx 2005 & 2006 daily....STEP is the best.  Here is a link to an article I downloaded regarding modeler accuracy and going between systems that have different kernals
http://multiterra.mooload.com/file.php?file=files/250406/1145977500/When+Bad+things+Happen+to+Good+CAD+Users.doc
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
