Welding detail.for 900 # Vessel
1.Kindly teach me regarding the welding joint detail for 36mm thk shell plate (316L) of 900 # vessel.
2.If the lifting lug is touching the capping of the welding joint b/w ellipsoidal head and shell of the vessel,than is it allowed to flush the capping to keep the lifting lug straight?Vessel is 800 mm od and TTL is approx.2.8m and 900 #.
Regards.
mechanical19k96@hotmail.com
Regards.
RE: Welding detail.for 900 # Vessel
Yes, the weld cap can be ground flush to improve fit-up with a lifting lug.
