Storing dynamic data in Excel
I have imported dynamic data from an external application to an Excel spreadsheet.  The data is constantly changing automatically and I want to trend it on a chart.
How can I sample and store this data in a column or row so I can build a chart with it?
Appreciate any ideas that don't involve heavy VBA.
RE: Storing dynamic data in Excel
Try to use named ranges. For example the data will be placed in column A. Go to insert-range-define, name range as data1, in the place for range address type
CODE
=offset(A1,0,0,count(A:A),1)
then click ok. Modify this formula to accomodate exact location of your data. When specifying chart series don't forget to type the sheet name
CODE
=sheet1!data1
. If the other columns have the same length then name next range
CODE
data2 = offset(data1,0,1)
Hope it will do!
Yakpol's solution to updating the chart is very nice. To update the data in your spreadsheet automatically, look in the menu for Data/Get External Data/New Database query.
Cheers,
Joerd
