python scripting
python scripting
python scripting
hi all,
I am trying to run a python script from the command prompt without opening abaqus cae. I am using now the command :
abaqus cae nogui=name.py
i am getting the following error, eventhough the script works just fine when i run it from cae.
AttributeError: 'Model' object has no attribute 'HomogeneousSolidSection'
File "shelf.py", line 39, in ?
    shelf_mod.HomogeneousSolidSection(name='steel',material='steel',thickne
ss=10)
is there any other command to use or what?
thanks
RE: python scripting
Did you use
"import section" ?
i used now "import section" and it works
thanks a lot xerf.
why i had to use it .. i thought  "from abaqus import * " will import all needed modules.
