How to speed up Menus in Acad 2007?
Hey.
ANyone know how to speed up the pull down menus in ACAD 2007.  It is VERY slow expecialy going into Customization Interface.
Matt
RE: How to speed up Menus in Acad 2007?
Wow!! 2007 already. I am still on 2004--type menu on the command line and select another menu file.  see if there is any change.
2006/2007 is a little different from 2005.  They don't use mnr mnu files.  They use cui files.  I tried that though and didn't work.
The program has a built in delay (just like winXP and the start menu) and I wanted to know if there is a system variable to change it.
Matt
If this is a windows thing, I think there is a TweakUI program available from Microsoft (free but no support) that you can use to reduce the delay.
