Translation help
Translation help
Translation help
I have a part I am trying to translate along a axis. when i choose translate and move the part the sketch data will not translate with it. I tried to fix together the sketch geometry with the part but no luck.
RE: Translation help
If you are working in v5, try first to create a plane where you want to place your sketch and use after change sketch support...
Fernando
to add to what Fernando suggested:
use Positioned Sketches, and either change the sketch plane or the origin location to 'translate' the sketch, and the part will follow along.
Thanks for the suggestions. Ill give em a shot. =)
best way to do it is using the Axis System. Create all the geometry Ref. to Axis system. Isolate the Axis System and then we can move the Whole part using Compass where we need to.
Amit
why isolate the axis system?
isolating the Axis system helps you to drag the part with the Axis system, If its associated you might get some error warnings.. or even you can create new axis system and them replace the old with new.
