Solidworks to Dwg ? [solidworks to AutCad?]
Hi ,
I was wondering if i would be able to convert a Solidworks file to AutoCad format? im using autocad 2002 and solidworks 2004. I Believe the correct format for AutoCad is DWG. Can the solidworks file be converted and opened on AutoCad ?
Advice appreciated
Dave
RE: Solidworks to Dwg ? [solidworks to AutCad?]
File\Save as\DWG - try looking in the help on this one... there is an option button that becomes available then... click on that and view more options.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Sure can, just do "save" as and select dwg. If you have multiple sheets in SW you have to do this for each sheet, far as I can tell.
With SolidWorks document/file open, do a "Save as" ... in the File Type you will see a list of all the formats that the file can be saved to.
Also a quick look in the SolidWorks Help file (yes SW does have one) smile for Export will list the options.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Just to be clear, you can convert a SW drawing file to AutoCad dwg format. You have to make the drawing first, though, right?
Hardie "Crashj" Johnson
SW 2005 SP 4.0 (reluctant to change)
Matrox Millenium G550
AMD Athalon 1.8 GHz 512 Meg RAM
SnowCrash, you can save a model to a .sat file.  This is a "dumb" solid format, but it can be read in to AutoCAD.
