Running Matlab Stand Alone
I would like to know what the requirements (software/hardware) are to run a stand alone application created created using the "mcc" command in matlab. I compiled the mfiles and can run the Stand Alone on my Computer which already has Matlab installed, but what if I want to run it on a machine without matlab? What is needed to be able to do so?
Thanks in advance.
RE: Running Matlab Stand Alone
Your question is not making sense.  mcc outputs C-code or executable, as explained in the help file.
TTFN
I have already converted an m-file to a stand-alone exectuable file. The requirements for running this application are the installation of MAtlab 7.1 Service Pack 3. But how is it is possible to start the executable file on a PC without the installation of Matlab 7.1 Service Pack 3. Please help me!
I suggest that you reread the help files.
You're supposed to use the Matlab Component Runtime installer (MCRInstaller) to port the required runtime files to the deployment machine.
TTFN
Thanks, i think installing the MCR is sufficient.
