python scripting
python scripting
hi all,
i am trying to start Abaqus with a python script directly from the command prompt using the command:
abaqus python name.py
where name is the python file name.
I am getting an import error:
C:\Abaqus\Commands>abaqus python shelf.py
Traceback (most recent call last):
File "shelf.py", line 1, in ?
from abaqus import *
File "Python/abaqus.py", line 12, in ?
ImportError: ababltin failed to import
it has to do with the import command(from abaqus import *). when i start abaqus cae and try to run the same script from cae everything works just fine.
please help.
thx in a advance.
please help.
thx in a advance.
RE: python scripting
i'm not sure whether you can import the abaqus module without the session object. this could be the reason for the message.
cheers
Indeed, it's impossible to import ABAQUS/CAE or ABAQUS/VIEWER.
To execute a script : abaqus script=shelf
but this requires a *.psf file. while i have a python shelf.py file. how can i solve this?
thx
C:\sctest>abaqus script=shelf.psf
File "Python/driver/script.py", line 86, in ?
File "Python/driver/application.py", line 119, in run
File "Python/driver/script.py", line 65, in execute
File "gear.psf", line 1, in ?
thanks for your patience.
this should work
