plate heat exchanger
hi all
i work in chemical plant & in our plant we have shell & tube
H-Exchanger (with sure service).
corrosion & leake &... is our daily problem.
i think to change our H-Ex to plate type.
-is it maybe?
-can i have some information about plate type H-EX & their
termal & mechanical calculation?
-is there software for those calculation?
thanx for ur help.
best regurd.
S.M.Mirjafari
-is it maybe?
thanx for ur help.
best regurd.
S.M.Mirjafari
RE: plate heat exchanger
What makes you think corrosion and leakage are associated with a S-T Hx, and not with a plate type exchanger?
You need to identify the factors for corrosion and leakage. If it becomes clear that they are because of the S-T design and that a plate type exchanger will resolve the issue, then you need to get in touch with a process equipment engineer.
The relevant formulas and procedures may not be of much use to you in the present case at least at this stage. So would be any software.
I doubt if this thread belongs in the Code Issues Forum.
rmw
