Laptop keyboard cable Connector replacement
hello, i was trying to replace a keyboard on a Toshiba Tecra S1 and i broke off the component that i insert the keyboard ribbon into, i was wondering if there was a product i could use or some other technique to connect the ribbon to the mainboard. thank you!
RE: Laptop keyboard cable Connector replacement
Original post is here:
http://www
Dan
Owner
http://www.Hi-TecDesigns.com
The site software will automatically create the link. As a bonus, you get a hover tip that tells you which forum it's located in, so that you can decide whether you want to bother adding it to your threadminder list.
TTFN
Dan
Owner
[img https://www.tipmaster.com/images/frog.gif] using the URL to your image. Full details of all the TGML markup are available at the bottom of the Preview Post screen - look for link in 'Click Here for the full list of TGML tags '
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts: www.essexsteam.co.uk
http://i72
http://i72
http://i72
http://i72
http://i7
